Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    427 LT1 would be suh-weet.
  2. #12
    Sep 2010
    1995 TransAm 385
    Any new updates on this block? My engine needs a refresh in the spring, and I wouldn't mind building a 427 instead of rebuilding my 385.
    1995 TA M6 E85
    Power mods: AFR 210 Comp Eliminators, LE LT4 intake, Custom LE cam, 12.5:1 385ci, M29
    Suspension: Koni's, 600/175lb Ground Control, 36.5/21mm sway, Fays2 Watts Link, rod-ended everything, C5 brakes, etc.
  3. #13
    cant go public with anything specific....but should be big news towards the end of this year.
    follow the project on Facebook for faster responses
    1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=241&dateline=12653889  02
  4. The Following 2 Users Say Thank You to Chopstix For This Post:
  5. #14
    its isnt a DART project...and it will be able to go 4.200+ x 4.000+
  6. The Following 3 Users Say Thank You to Chopstix For This Post:
  7. #15
    Nov 2014
    LDM
    1994 Camaro Z28
    Quote Originally Posted by Chopstix View Post
    Any way to post some of the info here? I despise Facebook/social media.
  8. The Following 3 Users Say Thank You to LDM For This Post:
  9. #16
    Apr 2018
    David Kirkpatrick
    1994 Pontiac Trans Am
    Chattanooga,TN
    Quote Originally Posted by LDM View Post
    +1
    1994 TA/ M6; Ford 9 inch; 3.21 gear; 385 all forged internals; Professionally ported LT1 heads; Comp Cams 224/236 573/571; Procharger P1-SC; Water/Meth injection; Kooks headers. QA1 coil overs and a little more.
  10. #17
    Jun 2020
    Chad Cox
    1997 Camaro Z28
    Any information out there on the aftermarket block? I see people refer to the Facebook page a lot. Are they talking about the "Aftermarket Ltx Block Committee" page? I never found any real info there, but I could be looking in the wrong places.
    Thanks!
    Chad
  11. #18
    This fizzle out like a wet optispark?
  12. #19
    allegedly chopstix ie ray hinton has something going on or some inside info that it is happening this year
  13. The Following User Says Thank You to SSlowBoat For This Post:
  14. #20
    None of this makes any sense in terms of product selling, but, this is LTX land where up is down.
  15. The Following 2 Users Say Thank You to shownomercy For This Post:
