Results 1 to 5 of 5
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Default Out like a light.
    Driving home the other day car dies just like the key turned off. Rush hour as well, pulled over try to restart no go. Waited a few then tried again cant get out too close to the traffic so something has to work. Turn key on off to hear fuel pump. Yes I hear it gage dose show fuel.But tach isnt moving it move like it has power but no more. Called AAA. Then tried again bang I move the car so I can get out. LSS got home and just today tried again started but after 10 min it died no issues just out like a light.Check to see if tach moves nope. Now my question is I need a new coil, icm, opti, car?
    Sent from my LG-G710 using Tapatalk
    The tach is driven based on the low resolution pulse from the Opti. The tach should move up 200-300 RPM while the engine is cranking.
    No scanner? DTC 16 for loss of Opti low res pulse does not turn on the SES light.
    Spark at the coil wire? At the plugs?
    Test for Opti signals, using a multi-meter:
    http://shbox.com/1/4th_gen_tech2.html#opti_test
  3. The Following User Says Thank You to Injuneer For This Post:
  4. #3
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Thanks its pouring rain now. I remember reading somewhere you said this wasnt sure. I'll check it out . It intermittent though It will start now but shut off when ever.
  5. #4
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Sound like when my ICM died once. Driving along and then poof, dead. Little while later, fired back up and lasted a few minutes, then poof, dead.
  6. The Following User Says Thank You to Fastbird For This Post:
  7. #5
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yup just like the key went out. Haven't tested it yet need my meter but its at work.
