Thread: Engine Swap Wiring Harness Q's
02-02-2020, 07:46 PM #1
Swapping a Caprice '94 LT1/4L60E into a '53 Chevy truck. Harness was butchered. Went to Pick-N-Pull and got a complete harness from a '96 Roadmaster.
According to LT1Swap.com I can interchange harnesses and PCM's. The PCM being used is the one from the '94.
So, biggest question, is - can anyone provide a layout of what connectors are for what on the '96 harness? I'm guessing I'll need to change some connectors. I have it laid out across the engine with the obvious connections made and plugged in at the transmission.
Thanks for any help. New to LT1's.
Josh Hucks
02-03-2020, 08:10 PM #2
Biggest issue off hand I can think of is the 96 PCM will be looking for a crank sensor that is not there on the 1994 motor. I don't think it will cause major issues outside of a SES light.
02-04-2020, 09:07 AM #3LTx Guru
- 2,279
He indicates he is using the 94 Caprice PCM.
Shoebox has a detailed, labeled photo of a 95 F-Body harness. Doubt the Caprice is the same, but here's the link:
http://shbox.com/1/harness.htmSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
02-04-2020, 10:03 PM #4
Thank you, I will keep trying to research. May just hold out for a ‘94 harness.
02-14-2020, 03:56 PM #5Xtreme Member
- 7,249
07-07-2020, 06:34 PM #6
I pulled a lt1 out of a 96 impala and want to drop it in my 65 impala. I have the pcm and harness what would my first step by to get power to the pcm
07-15-2020, 10:35 AM #7
Since this is going into a different vehicle, you'll need to get the wiring diagram for a 96 to determine which pin goes to what wire.
http://lt1swap.com/lt1_pcm_pinout.htm
That site has a good list of the pinouts. You'll need to connect the power and grounds to get the PCM powered up properly.
