Results 1 to 5 of 5
    Feb 2019
    Josh
    53 Chevy Truck (LT1 swap)
    Default Engine Swap Wiring Harness Q's
    Swapping a Caprice '94 LT1/4L60E into a '53 Chevy truck. Harness was butchered. Went to Pick-N-Pull and got a complete harness from a '96 Roadmaster.
    According to LT1Swap.com I can interchange harnesses and PCM's. The PCM being used is the one from the '94.
    So, biggest question, is - can anyone provide a layout of what connectors are for what on the '96 harness? I'm guessing I'll need to change some connectors. I have it laid out across the engine with the obvious connections made and plugged in at the transmission.
    Thanks for any help. New to LT1's.
    Josh Hucks
    Biggest issue off hand I can think of is the 96 PCM will be looking for a crank sensor that is not there on the 1994 motor. I don't think it will cause major issues outside of a SES light.
    He indicates he is using the 94 Caprice PCM.
    Shoebox has a detailed, labeled photo of a 95 F-Body harness. Doubt the Caprice is the same, but here's the link:
    http://shbox.com/1/harness.htm
    Feb 2019
    Josh
    Thank you, I will keep trying to research. May just hold out for a ‘94 harness.
    Eh
    Quote Originally Posted by Jhucks03 View Post
    96 harness will plug right into a 94 pcm, pcm connectors are the same. you will just have unused stuff (rear o2's, crank sensor, different coil connection)
    2015 Camaro 2SS 1LE
    1989 Camaro RS - Le2 H/C, SBE, TH350 swap
