Results 1 to 5 of 5
    Aug 2013
    JB
    Atoka,TN
    Default Torque converter selection
    Guys, there's a lot of smart people on this forum and I appreciate your input. I have a 97 Z28 that I have decided to sell but before I do, it needs a new higher stall converter. The car is stock weight, T-tops and factory rear gear. The engine was rebuilt before I bought the car and the engine has a Comp Cams #467 so, because I intend to sell it, obviously, I would like to do this right but with minimal expense. I've been eyeing the 2800-3200 with lock up converter from Monster. Has anyone had any experience with this converter or similar setup, etc?
    Sep 2014
    Joel
    Colorado
    I have not had any experience with monster. I will recommend contacting Cahall performance transmission and speak with Gail.
  3. The Following 2 Users Say Thank You to Camaro96 For This Post:
  4. #3
    More often than not, you get what you pay for.
    Circle D, FTI, Yank, PTC etc are good brands
  5. The Following User Says Thank You to shownomercy For This Post:
  6. #4
    Aug 2013
    JB
    Atoka,TN
    Quote Originally Posted by Camaro96 View Post
    Your right. Frank did an awesome job on my 94 Z28 and I will definitely use CPT again but only if I was going to keep this 97. I'm not in a position to put $2000+ more in this car's trans/converter to maybe get $3500 for it.
  7. The Following User Says Thank You to Cathead For This Post:
  8. #5
    Sep 2014
    Joel
    Colorado
    Quote Originally Posted by Cathead View Post
    I would contact Gail you can just purchase a converter from her
  9. The Following User Says Thank You to Camaro96 For This Post:
