Results 141 to 150 of 351
Thread: Haggard-hawk
08-26-2021, 01:13 AM #141Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
So I did a track night @ NJMP Lightning. Really realllllly like the course, it's full of blind corners and sweepers. I think I'm going to need a baffled oil pan though as the oil pressure would get wonky around turn 7 (past the bridge) if I downshifted and kept the revs up. At corner exit, the pressure would dip to 20psi on the gauge and take a second to build back up as I'm going flat out in 3rd, so I started grannying it in 4th the whole way instead.
The Following 2 Users Say Thank You to Catmaigne For This Post:
08-27-2021, 03:56 PM #142Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
I ordered some 18x10.5 C5z reps to test out and there was even less clearance than my friend's higher offset reps. Back to JEGS they go.
I think the next wheel I'm going to try are 18x10.5 Stingrays (CV27A, non dished version).
Also found a bitchin deal on a new Kevko 1091RR road race oil pan, so I'll swap that in over the winter.96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
08-31-2021, 02:11 PM #143
We're taking advantage of the extended weekend and hitting an autocross in NH. Based out of Canaan. I watched a video and it looks like half road course half autocross. Not a lot of cars entered and the hotels are outrageous but I like racing with new people. Its 7 hours each way for us. Just hoping that the weather stays clear. So far it says 76 and sunny.
Here's the link: https://www.motorsportreg.com/index....A1DF6F32C3F13B
09-01-2021, 06:48 PM #144Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
09-03-2021, 03:33 AM #145Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
Decided to stay with the C5z reps, run a small spacer, and add extended Moser wheel studs. Got the tires mounted today and did a test fit. I want to raise the front end a tad with some washers under the shock mount (like BMR SA002, but for cheapasses like me) and do some fender rolling or grinding to the inner lip.
0902211656d.jpg96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
09-12-2021, 11:32 AM #146
Hows the weather looking for Saturday?
The Following User Says Thank You to joelster For This Post:
09-12-2021, 09:17 PM #147Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
09-13-2021, 08:20 PM #148
I'll wait until Thursday to make my decision. Just got 2 new trailer tires. Ordered Vorshlag camber plates too but I won't have them installed by then though.
09-14-2021, 12:20 AM #149Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
Did another track night @ Pocono. Shaved 7 seconds off my previous best and got to chase a bunch of corvettes around in earlier sessions.
09-14-2021, 07:03 AM #150
Great videos! Almost 130 down the straight. Check your fuel level needle in the hard turns, it's fluctuating by over 1/2 a tank!
1995 Firebird Formula, M6, ram-air, C7 hubs, BMR/Strano/Founders/Koni suspension, bolt-ons, Recaros, 315 Nankang AR-1's
2010 Corvette Grand Sport, A6, Kooks/Halltech, 418 rwhp
1966 Mustang 289-2V, auto, factory original
