MoeBig
Results 1 to 8 of 8
Thread: Hi from Iowa
    Jul 2018
    Kevin Groen
    1997 Trans Am WS6
    Default Hi from Iowa
    This is my car 1997 WS6
    .40 over
    4 bolt main
    11.1 compression
    magnaflow catback
    steel oil pump shaft
    trick flow 185 heads
    220 227 cam
    7.2 push rods hardened
    NSA 1.6 roller rockers
    30# injectors
    XS power long tubes
    poly motor mounts trans mount
    MGW shifter
    90k miles car has been taken care of very little rain no winters
    BMR lowering springs Koni shocks trailing arms panhard rod LCA relocations brackets C5 brakes
    Eh
    love me a clean black t/a. nice ride and welcome
    2015 Camaro 2SS 1LE
    1989 Camaro RS - Le2 H/C, SBE, TH350 swap
    Jul 2018
    Kevin Groen
    1997 Trans Am WS6
    Thanks a bunch. Have a great day.
    Welcome ! ! !
  5. The Following User Says Thank You to Injuneer For This Post:
  6. #5
    Sep 2011
    95 ta
    little falls mn
    Car looks very clean. Welcome aboard!
    Adam Legatt 95 trans am, 355 LE ported 21* TFS heads SS4000, 9'' 11.18@ 121.5 mph
  7. The Following User Says Thank You to adam85 For This Post:
  8. #6
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Car looks good. Don't see them like that too often anymore. Welcome!
  9. The Following User Says Thank You to Fastbird For This Post:
  10. #7
    1996 Camaro Z28, 1994 Trans Am GT, 1985/1996 Corvette CLONE
    Quote Originally Posted by PITALT1 View Post
    .40 over
    4 bolt main
    11.1 compression
    magnaflow catback
    220 227 cam
    30# injectors
    XS power long tubes
    MGW shifter
    Looks real nice man! Welcome!
  11. The Following User Says Thank You to popo8 For This Post:
  12. #8
    LTX Regular
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Nice car!
  13. The Following User Says Thank You to Brandon++S For This Post:
