Results 1 to 9 of 9
Thread: Spark plug heat range
Hybrid View
12-21-2019, 11:16 AM #1LTX Regular
- Aubrey
- (2) 1994 Camaro Z28
- Janis Joplin's neck of the woods
- 204
I have installed Denso DNP-4713 spark plugs from Summit Racing in my engine, which have a heat range of 16. The AC Delco plugs I removed only have a number 14 on the ceramic. I tried to research if this was the heat range reference number but can't find anything in writing. All the plugs I removed have black soot that apparently didn't come clean with spark detonation, so I'm thinking the 16 heat range on the Denso iridium plugs will accomplish this without being too hot for my N/A engine. I went with Taylor Thundervolt 8.2mm wires, an upgrade from 7mm wires I removed. Does anyone know of a source I can find the heat range on the AC Delco plugs? I found a chart explaining the heat range differences and 16 seems to be the hottest to safely run in my engine, and Summit Racing references the Denso plugs are compatible to my engine.
'94 Z28 Red, SLP Ultra Z hood/air box/spoiler, LT1 w/deletions & mods, 4L60e Pro Race build by CPT, Pacesetter LTs with stainless Speed Engineering LS1 True Duals, LS1 front brakes, Kenny Brown Double Diamond SFCs.
12-21-2019, 11:47 AM #2LTx Guru
The replacement for the stock plugs, in a relatively stock LT1 is an NGK TR55 (or TR55ix iridium). Find an equivalent to that plug in the brand you prefer, if not NGK.
Not all plug manufacturers use the same heat range designations:
https://www.sparkplugs.com/learning-...or-hotter-plugLast edited by Injuneer; 12-21-2019 at 12:10 PM.
12-21-2019, 01:07 PM #3LTX Regular
- Aubrey
- 204
I found the Heat Range Cross Reference Chart in that link which shows the Denso plugs and NGK plugs have the equivalent heat range. Thanks for the information Injuneer...I appreciate it.
The Following User Says Thank You to Ardent_Z28 For This Post:
12-22-2019, 04:41 PM #4Xtreme Member
- 7,266
12-23-2019, 09:08 AM #5LTX Regular
- Aubrey
- 204
My Denso plugs (16) are the equivalent heat range as the NGK plugs (5) Injuneer mentioned. I just got the engine back on the K-member yesterday, still gotta ways to go b4 I fire it up. Hopefully these plugs will go 80k-100k miles as advertised cuz my Pacesetter LTs don't make access to 'em very easy.'94 Z28 Red, SLP Ultra Z hood/air box/spoiler, LT1 w/deletions & mods, 4L60e Pro Race build by CPT, Pacesetter LTs with stainless Speed Engineering LS1 True Duals, LS1 front brakes, Kenny Brown Double Diamond SFCs.
12-21-2019, 02:26 PM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Is your motor mainly stock what all do you have done to it your signature says deletions and mods
12-22-2019, 04:51 AM #7LTX Regular
- Aubrey
- 204
It is all stock except the cam...Duration @ .050 intake is 220 & exhaust is 230 with 114 LSA. Beehive valve springs in the heads, so it is slightly more aggressive than stock. AIR/EGR deleted too.
12-22-2019, 10:20 AM #8LTx Guru
You're OK w/ stock heat range.
12-22-2019, 02:00 PM #9The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Stock heat range
