Results 1 to 9 of 9
    Javier
    1997 Trans Am WS6
    The Final Frontier.
    Default 3" catalytic converter recommendation
    I finished up installing a true dual system from Speed Engineering, but I need to get some cats because:
    1) since I have to get this thing emission tested
    2) the driver side pipe doesn't quite reach the header
    Does anyone have recommendations?
    I was looking at the Magnaflow spun ones but I'm worried about ground clearance since they aren't flat and they don't have a heat shield
    Also I'm pretty disappointed with their technical help line. I tried to get info on their universal cats and they just flat refused, they wanted a car to look up on their application guide, so I finally told him and all they would give me was stock replacement parts
    I tried to ask about the 59929 but they wouldn't tell me anything like if it's for Obd2 or later or anything, just kept saying the guide doesn't show that as compatible
    97 Trans Am WS6, LT1 factory 4bolt freak, M6,
    68 Firebird 400, YC 400, 670 heads M4
    14 Fiat 500e
    , 83kW motor, 24kWh 364 V battery
    I ran a pair of Carsound 3" cats in a Y-pipe (which was eventually replaced with true duals. The pic shows them while the Y-pipe was being fabricated at Mufflex. Denny recommended the Carsounds, and the setup passed NJ emissions. All of this was 19 years ago, so I have no idea if they even sell the same cats.
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    What is your state's regulation on emissions testing? Usually once a car hits a certain age, it is exempted.
    -Ryan
    93 Z28 M28
    Mod List
    Javier
    1997 Trans Am WS6
    The Final Frontier.
    I looked online and couldn't dig up anything on car sounds that wasn't really old, thanks though
    14 Fiat 500e
    Javier
    1997 Trans Am WS6
    The Final Frontier.
    Quote Originally Posted by Z28pr0jekt View Post
    Texas in my county requires Obd2 testing on vehicles 96 and newer, so I'm screwed no matter how old my car is
    14 Fiat 500e
    Quote Originally Posted by captainofiron View Post
    In my experience, OBD2 testing is a easy enough test to pass if the visual aspect is not to stringent. (if it is you failed regardless of what cats you put in) Is the car tuned for turning off all emissions ready lights?
    Car Sound Exhaust owns Magnaflow. Appears the converters are now branded as MagnaFlow.
    http://www.marcomuffler.com/magnaflow.html
    https://www.magnaflow.com/products/9...r?aces=9577099
    California and New York require CARB certified replacement cats. The other states do not.
    Federal law says that you cannot relocate the cat(s) from stock, and cannot change the number of cats. Not all states enforce Federal law.
    Javier
    1997 Trans Am WS6
    The Final Frontier.
    I meant to post that there is a two speed idle test in my county as well, the place I have taken it in the past doesnt really do a visual, they just drive it into the bay and plug it in
    so right now I am throwing an MIL for EGR flow, pretty sure it was due to my cut out leaking, BUT now that I put in a new exhaust and chunked my homebrew y-pipe, I am hoping its leak free and will no longer throw the MIL
    interesting, well that kind of sucks, after dealing with the Magnaflow tech people I have more than a bad taste in my mouth, I called again asking for specs on the 59929 and got the same legalease and telling me that would not give me any info unless I had an application
    in my experience the inspectors dont really care if you have longtubes or moved the cats, as long as you are running cats and the exhaust doesnt smell like raw fuel
    14 Fiat 500e
  9. #9
    To get the one I linked (3” universal w/ heat shield) I entered 1994- Chevrolet - Camaro - Z28 - 5.7L V8. That looks similar in size and design the the ones I had, but mine did not have the heat shield. I had the passenger side in the stock side dimple for the stock cat. Drivers side was hanging pretty low, but it never hit anything. But I have AS&M single-cat mid-lengths with modified collectors/extensions so they can be run as duals.
