MoeBig
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default Chassis measurements
    Does anybody happen to know where I can find a list of measurements in the chassis I'm wanting to check and see if my car is still square and straight before I weld in my roll cage and subframe connectors.
  2. The Following User Says Thank You to zooguy For This Post:
  3. #2
    1994 factory service manual. Section 11, detailed diagrams starting on page 11-30.
    Free download from a GaryDoug:
    https://www.mediafire.com/?40mfgeoe4ctti
  4. #3
    Eh
    your car? probably not straight in the slightest
    2015 Camaro 2SS 1LE
    1989 Camaro RS - Le2 H/C, SBE, TH350 swap
  5. The Following User Says Thank You to SSlowBoat For This Post:
  6. #4
    Apr 2010
    Troy
    I know right ... these pictures are from the 24th of November whenever I set my new personal best of a 10.17 and a 1.333 60-foot time
  7. #5
    Eh
    Didnt you cut a hole in your firewall to access bellhousing bolts?
    2015 Camaro 2SS 1LE
  8. The Following User Says Thank You to SSlowBoat For This Post:
  9. #6
    Apr 2010
    Troy
    Not in the firewall but more so like the trans tunnel
  10. #7
    Apr 2010
    Troy
    #thebeaterbird
  11. #8
    Eh
    #thebeaterbird
    and youre worried about the car being "straight?".
    2015 Camaro 2SS 1LE
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #9
    Apr 2010
    Troy
    I don't want to reinforce a twisted chassis
  14. #10
    Eh
    then you should probably be looking for another shell, since these cars "twisted" with stock hp levels, and no holes cut in them...
    2015 Camaro 2SS 1LE
