Results 1 to 9 of 9
Thread: Coolant Leak @ Water Pump
11-30-2019, 10:49 AM #1LTX Member
- Sep 2016
- Brandon Reitz
- 1995 Pontiac Trans Am
- 53
So I found a huge puddle of coolant under my LT1 and I jacked it up today and noticed it was wet around this port. Looks like it wiggled its way out some? Can this be pushed back in or does anyone have any suggestions on how to fix this leak. See pictures below. It's a 95 LT1, I put the water pump on a few years ago and there's not even 500 miles on it probably. Thanks
11-30-2019, 09:04 PM #2LTX Master
- Aug 2013
- JB
- 1994 Camaro Z28 1996 Camaro SS
- Atoka,TN
- 531
You could try to clean and dry it really well and apply a cold weld around the seam
Sent from my SM-G955U using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
12-01-2019, 12:25 AM #3Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Or replace the pump.
12-01-2019, 11:47 AM #4LTX Member
- Sep 2016
- Brandon Reitz
- 53
Is that piece "serviceable", like is there an O-Ring behind it that can replaced? Sucks there's barley any miles on this pump smh...
I'd weld it but I don't have one also
12-01-2019, 01:03 PM #5Long Live the Opti
12-03-2019, 10:11 AM #6Xtreme Member
- 7,249
Supporting MemberPull it out, it can be tapped for 1/2" npt and use a regular 1/2" npt to barb brass fitting
Sent from my SM-G975U using Tapatalk2021 Charger Scat 392
12-03-2019, 06:45 PM #7LTX Member
- Sep 2016
- Brandon Reitz
- 53
Will do soon, I'm off over 2 weeks soon so I'll work on it then. Thanks
01-18-2020, 07:38 PM #8LTx Guru
- Online
- 2,279
Have you fixed this?
Is this a Duralast pump? I've got a guy on CZ28 with the same problem on a new Duralast pump.
03-24-2020, 10:21 AM #9LTX Member
- Sep 2016
- Brandon Reitz
- 53
Fixed this over the weekend, took the radiator and all the hoses off to get to the front of the water pump. Pushed the fitting in tight and used a sealant around the pipe just to be safe.
