MoeBig
Results 1 to 1 of 1
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default 5" Autometer Ultimate playback dual range tach
    I have a dual range tachometer everything works on it perfectly fine you can set two different shift light points and it has a playback feature as well or you can record up to 40 seconds and Playback the run after you're done or you can utilize it into your data logging
    My ad of Facebook shows $350 but for yall on here ill take $300
    I'm changing up a few things on car this winter.
    And just before anybody comments on that no that is not the actual bottle pressure nothing was wired up on my car at that time.
