Results 11 to 11 of 11
Thread: 24x LTX Converted Harness - 1995
01-05-2020, 10:28 AM #11
Realized I should have added more to add, apologies
1) Harness is setup for speed density, I am not 100% what I did with the MAF plug. It may be depinned and tucked into harness. I will check.
2) The routing of the harness was made to travel through firewall. This may be backwards of how a factory car would want to route things. I can lay it out and measure distances to connectors if that would help.
3) Mentioned before but it is pinned for a 4L80e, but this can be swapped back to run a 4L60e fairly easy. (it has the two VSS sensor hookups)
4) Fan kick on leads are fairly short (prob a foot or so). I was running a aftermarket relay panel so I had a separate harness for that.
MattCorrelation does not imply causation.
