Results 1 to 6 of 6
    Default cloyes double row timing set on 96-97 lt1
    will it work with the reluctor wheel?
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    With the stock cover? No. There is a EFI billet cover it will work with though.
    You can't clearance it like the 92-95 covers. I have one on my 95 setup with a facktory cover that I clearance with a grinder
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    The billet dbl roller cleared my 96-97 cover but most say they won't. Not sure if I just got lucky or maybe there's a difference in thickenss between the billet and standard dbl roller.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
    The cover I have now is a 95. I will have to dig thru my paper work to see the part# on the set I used. I wrnt to switch to the 96-97 cover so I can run the 411 pcm.
    Apr 2012
    Mike
    Conshohocken, PA
    You could run the ZZ4 timing set and a reluctor behind the 96-97 cover. It has the same HD chain and crank sprocket as the LT4 Extreme Duty set for way cheaper. But to fit a double roller you're gonna need a billet cover to get everything inside. I went that route because I was determined to waste money at the time.
