    Jan 2009
    1997 Camaro SS, 1996 Camaro Z28
    Rochester, NY
    Default 383 LT1 engine w/EFI Connection 24x
    Complete 383 LT1 engine built for forced induction with less than 700 (seven hundred) miles. The engine is in excellent condition with no issues. Recently removed from a well-running vehicle. Although the engine was built to support a significant amount of power in a forced induction application, it makes great power in naturally aspirated form.
    I have quite a bit of paperwork on this engine that will go to the new owner. I also have all of the flow numbers for the heads.
    383 LT1
    - 1996 F-body 2 bolt block converted to 4-bolt splayed
    - JE (not SRP) 2618 forged pistons w/-16cc dish
    - Eagle 4340 forged H-beam rods with ARP bolts
    - Eagle 4340 forged 3.75" crank (1pc rear main)
    - Internally balanced (required zero balance flywheel/flexplate)
    - ProGram 4-bolt splayed main caps
    - Block clearanced for stroker crank
    - 4.030" bore
    - Cometic MLS head gaskets
    - Milidon 7qt oil pan (F-body style - will need Corvette pan if used in a C4)
    - LT4 Extreme duty timing set
    - Polished timing cover
    - Melling HV oil pump
    - Milidon pick up
    - Comp Cams 242/254 cam on 114LS
    - GM lifters
    - GM LT4 cylinder heads CNC ported by Modern Cylinder Head (have flow sheet), 2.00" intake/1.56 exhaust valves, Comp 987 springs, 55cc chambers
    - GM LT4 intake manifold ported by Modern Cylinder Head
    - BBK 58mm throttle body
    - Chrome tall valve covers
    - ProForm 1.5 aluminum roller rockers
    - Comp Cams chromoly pushrods
    - ARP head studs
    - EFI Connection 24x crank/cam reluctors and sensors installed
    - Professional Products LT1 damper
    $3000 complete
    -OR- I'll split up the top end and short block:
    -Top end (heads, intake, TB, valve covers, rocker arms, push rods) $1500
    - Short block (w/24x) $2000.
    Buyer will need to pick up in Rochester, NY
    Aug 2019
    Ryan Parliament
    1997 Pontiac Trans Am WS6
    Can’t read your ad Jason, it’s almost blacked out
    Aug 2016
    Joe
    95 Trans Am
    Pennsylvania, New Bloomfield
    PM sent. I think.
    Jan 2009
    Rochester, NY
    Joe, I just sent you a text.
    Jan 2009
    Rochester, NY
    Sold, thank you
