Results 1 to 5 of 5
Thread: What skinny tire on the street?
09-23-2019, 09:05 PM #1
I was wondering what everybody uses on the street, for a skinny tire? Radial or "track" tire, like a M/T, Hoosier, Moroso? I want to make sure the tire is strong enough, for street use and the roads around here SUCK.
S60 rear
09-26-2019, 02:25 PM #2VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
This is what I run. Not the lightest tire but it is a street tire.
09-26-2019, 03:16 PM #3LTX Regular
- Online
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
I have the same ones. I think they're pretty light for a radial. Not as light as bias ply but have a good ride quality if you're going to be using them on the street.
Sent from my VS501 using Tapatalk1995 FORMULA M6
09-26-2019, 08:52 PM #4
Thanks for the suggestions!
S60 rear
03-01-2021, 08:03 PM #5
Interesting choice of tire. I'll check 4WheelOnline if they have more options for that kind of tire. I'm planning to purchase replacement tires this month.
