Results 1 to 9 of 9
    Sep 2017
    Brian Rota
    1995 firebird
    Default Motor noise/clunk LT1
    Hello
    I have a 1996 LT1 firebird.
    I have a noise which I think is on the passenger side.
    The car has a new water pump
    I took the belt off and can still hear the noise.
    It sounded like it was coming from rockarms but they seem to be running. I do not know the history of the motor. I was surprised to see roller rockers.
    The car seems to have oil pressure I do have CEL for Crank position sensor
    If you watch the video below you can hear it. I think it sounds like it washing machine with shoes in it.
    LTX Regular
    Sep 2011
    95 ta
    little falls mn
    Sounds like a rod knock to me.
    Adam Legatt 95 trans am, 355 LE ported 21* TFS heads SS4000, 9'' 11.18@ 121.5 mph
    Sep 2017
    Brian Rota
    1995 firebird
    Quote Originally Posted by adam85 View Post
    Is there an easy way to test/determine?
    Thank you
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    I'm sorry to say that's rod knock all the way man. How's oil pressure? Probably lower than normal? Maybe really low?
    Sep 2017
    Brian Rota
    1995 firebird
    What I was expecting but was hoping an exhaust leak or something. Will check oil pressure later.
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    I was going to say exhaust leak as well. but rod knock maybe just rev it a bit it should make a more rivmic sound on declaration but that can be the big end
    Sep 2017
    Brian Rota
    1995 firebird
    It seems to be on the top under intake sounded like running through valve cover.
    Where could the exhaust leak be?
    I will try to run it and check the oil pressure.
    Sep 2017
    Brian Rota
    1995 firebird
    OK i tightened a couple exhaust manifold bolts because I was going to change them.
    Put the valve covers back on.
    Put heat loose heat shield back in place.
    Oil pressure was 60 on start up and I did not see it go below 20 when idle and hot.
    I dont hear it or hear as much
  9. #9
    LTX Regular
    Sep 2011
    95 ta
    little falls mn
    Hard to tell over the internet but I can still hear a knock in the videos. I would drain the oil and cut the filter open at this point.
