American Powerhouse
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Jun 2019
    Nick
    1995 Camaro Z28
    Pennsylvania
    Cool Hello from Pennsylvania!
    Hey everyone,
    New member here. I used to frequent LS1Tech and CamaroZ28.com, but haven't been active on those forums for a few years. Figured that this would be the best site for current LTX stuff.
    Anyway, I have a 1995 Z28 which I just cam swapped over the winter. Unfortunately a few recent dyno runs to 6200 RPM either revealed a weakness in my stock 67,000 mile bottom end, or a weakness in my ability to successfully perform a cam swap...made 356/362, but I have some nice "shiny" oil as a result. Going to be dropping the engine/trans combo here soon to find out exactly which bearing decided to start destroying itself (I'm leaning towards a cam bearing).
    It's forced upgrade time, and I'm definitely not going to go with the majority of the crowd and just LS swap. I'm planning for a 500-550 flywheel hp N/A 383. I will try to post some updates as I proceed with tear-down, machining, and reassembly. I have an "in" with a great local automotive machinist, and I'm excited to work with him throughout the process and expand my knowledge along the way.
    LTX Regular
    Aug 2013
    JB
    94 Camaro Z28
    Atoka,TN
    Welcome to the forum! LTX and Pennsylvania...I think you've found a home here
    1996 Camaro Z28, 1994 Trans Am GT, 1985/1996 Corvette CLONE
    Welcome to the family man... make sure u start a build thread with lots of pics.
    We are a simple people and pics make us happy.
    LTXtech.com is my drug...
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Quote Originally Posted by LTX Nick View Post
    Hey everyone,
    That's always a risk taken when you open up a motor. Sorry it had to happen to you. I'm about to take the same chance with my car that it almost turn key ready again.
    What are your motor plans? 500-550 flywheel isn't unrealistic for a goal.
    Jun 2019
    Nick
    1995 Camaro Z28
    Pennsylvania
    Thanks all! And I will be sure to take many pictures along the way. I tried to take as many precautions as possible. Cleaned all of my parts and followed the instructions (when given), took advice from reliable sources, took lots of measurements and followed all torque specs. I’m really curious to see if my cam swap caused the failure, or if maybe a main or rod bearing was on the verge of going. I don’t have any knocking, but I have a squeak on startup (it stops after a minute or so) that I thought was a pulley. Took the belt off and the noise was still present. Listened to the water pump and Torqhead sensing unit, but no noise from them. Finally drained the oil and saw really fine bronze colored shavings, and I had already changed it since break in.
    So far, plans are (subject to change) forged pistons and rods, probably a forged 3.75” stroke crank, studded 2-bolt mains, either AFR 195 or 210 heads, LE ported trickflows, or 200cc ported stock castings if AI would ever respond to my emails...
  6. The Following User Says Thank You to LTX Nick For This Post:
  7. #6
    Btw, where in PA are u from?
  8. #7
    Jun 2019
    Nick
    1995 Camaro Z28
    Pennsylvania
    I'm in South Central PA. York County.
  9. #8
    Oh cool, I'm in Berks County near Reading.
  10. #9
    Jun 2019
    Nick
    1995 Camaro Z28
    Pennsylvania
    Yea, you definitely aren't too far away from me. Who knows, we may even run into each other sometime!
  11. The Following User Says Thank You to LTX Nick For This Post:
  12. #10
    Dec 2011
    Mark
    Altoona, PA
    Welcome aboard! Great group here with tons of knowledge. Never be afraid to ask any questions. Your new build will be plenty fun on the street and at the track. Iím from PA also, Blair county area. Keep us posted on your build.
