Results 11 to 20 of 36
05-28-2019, 12:33 PM #11Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
Even on this note, I had a datalog show voltage change on an IAC that was stuck open. I thought the IAC was good until I finally took apart the car. This was causing fuel to load up and a hard time idling. I actually drilled the IAC hole larger before actually checking the IAC like a dummy.
05-28-2019, 01:02 PM #12Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Yeah. Seen that too. Well hopefully you'll Square it away.
Sent from my LG-G710 using Tapatalk
05-28-2019, 02:03 PM #13LTx Guru
The IAC value you see in the PCM is how many “steps” it is telling the IAC to open. 0 = closed; 156 = fully open. 20-40 counts at idle is “normal”. There is no feedback as to the actual position of the IAC pintle. And there is no voltage reading in any scans I have ever reviewed. You can test the IAC motor per Shoebox’s instructions:
http://shbox.com/1/iac2.jpg
When you hold the accel pedal to the floor before cranking, it puts the PCM in “clear flood” mode. If the ECT sensor is correct as you indicate, you appear to have something flooding the engine. When you tested the fuel pressure, did you let the pump prime without trying to start the engine? If so, when the pump shut down (hopefully at 40 PSI or above) how fast did the pressure bleed down?SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
05-28-2019, 02:27 PM #14Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Well IMD that's what I meant. Does it change? It's been a bit since I trouble shot one. I've got old timers. Carry on. Nothing to see here.
Sent from my HP Pro Slate 8 using TapatalkLast edited by Stormyweather; 05-28-2019 at 02:31 PM.
05-28-2019, 02:36 PM #15LTx Guru
Sorry about that. I was just trying to help.
05-28-2019, 02:37 PM #16Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
What about me being oder then dirt?
Older then.
05-28-2019, 02:40 PM #17Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Your a great asset Mr.
05-28-2019, 03:35 PM #18LTX Member
- Mar 2019
- Danno
- 1996 Firebird Formula
- South Dakota
- 28
I will check the fuel pressure again when I get home tonight. unfortunately, I don't have a scanner that shows IAC counts, I will test the IAC motor . I noticed that it had colder plugs in it. The plugs that were in it have a heat range of two. The plug listing for the same type of plug is a heat range of four. I don't know if that makes a big difference or not. After pondering some more, I may have flooded the engine myself. When it wouldn't start, we did a lot of cranking when we were checking the different parts of the ignition system. So much that we pretty much ran the battery all the way down.
1996 Firebird Formula (A Working Progress )
2002 Camaro Z/28 M6 (Sold but not Forgotten!)
05-28-2019, 04:25 PM #19Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
05-28-2019, 11:24 PM #20LTX Member
- Mar 2019
- Danno
- South Dakota
- 28
I checked my fuel pressure. It went to 42 psi when the key was turned on. I let the gauge sit for about 1/2 hour and it only bleed down to 39-38psi. I then pulled the IAC motor. The pentle was retracted all the way and I got 49 ohms on both coils of the IAC. The IAC passage was pretty clean, as well as the sensor. I compression checked the engine. Lowest cylinder was 165 psi and the highest was 185 psi. I then checked the ect on the scanner again. It was at 41 degrees. I pulled the plug off the ECT and there was corrosion in it. I cleaned the contacts, and it now reads 66 degrees, about the same as the garage. I was mistakenly looking at the intake air temp sensor last time. I don't know if this is a clue for not, I noticed that when I was doing the compression check the tac would read about 300-400 rpm while cranking, then it would erratically jump around for about a 1/2 sec, then read normally again.
