Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Default AFR 210 vs AI Trickflow 215
    Looking for new heads for my 396 and I'm torn between these 2. Anyone have any experience with them? Car is a full weight street car with a T56.
    95 Cyber Grey Formula
    396 M6
    LE 244/252 .636/.636 110
    LE 215cc Trickflows
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    Michael glick runs ai 215 21s and runs low 10s with a sr 396 making well over 600hp na
    Sent from my SM-G965U using Tapatalk
    1995 Formula 383/t56 gone
    1993 Camaro Z28, forged, TFS heads, solid roller, prosystems carbed, t56 swapped spec 3+
    "Nitrous is like Tara Reid with an STD. You want to hit it, but your afraid of the consequences"
    Just curious what the decision on this was? I know the thread is a few months old now but I've read some horror stories of Trick Flow's valvetrain geometry. Great flowing cylinder head but if it's going to prematurely wear out valve guides because the rockers won't align on the valves even with adjustable guide plates, also have read that the machine work on them causes pushrods to jump out of lifters. Curious here?
    1994 Chevy Camaro z28
    IL
    I've had my AI 215's for years now. No problems with lifters, PR or guides. The machine-work and product were top notch!
    S60 rear
    Quote Originally Posted by Vicious95Z28 View Post
    Running LE Trickflows. The guide plates that came with them had to be ground a little bit to go a hair closer together, but other than that no issue.
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    AI 212 TFS heads here, 520 RWHP NA. I'm happy with them but since I've converted to a single plane and SR cam I've been curious if I've out grown them.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    Quote Originally Posted by 96LT1355Z28 View Post
    Is this bottom end still a 355?
    Dec 2011
    Louisiana
    AFR 210's have great flow numbers but also have their issues with quality control and rocker arm alignment. I don't have any experience with Trick Flows so I can't say one way or another.
    See this thread that involves AFR210's;
    http://www.ltxtech.com/forums/showth...p-end-overhaul
    Oh I never actually finished the thread because my photos kept disappearing. The aggravation was just too much for me.
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
  9. #9
    FYI For anyone trying to go AI, find them used. Otherwise go thru Karl Ellwein, he can get them quicker
  10. #10
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    AI is still doing gen 2 heads?
    1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
