Results 1 to 6 of 6
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    Default Ideal Target AFR @ Idle
    What's the ideal target AFR for idle on a car with a decent amount of overlap?
    1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
    Sep 2014
    Joel
    Colorado
    Quote Originally Posted by myltwon View Post
    Need more info
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    what info do you need me to provide? mods in sig
    "Usually" the pcm is going to try and maintain stoich, at startup you usually want it a little rich like a choke on a carb, since there is no load on the engine at idle 14-15 is ok. but depending how much overlap you have may be more or less.
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    So at operating temp I would want leaner than stoich, but at cold start up target stoich?
    stoich is 14.7, you really want it a little richer especially in cold weather.
