Results 1 to 10 of 10
Thread: LT1 ticking
07-14-2018, 08:56 PM #1
LT1 ticking
I've searched the entire internet.1997 WS6 90k miles on car. Not original engine don't know the history. I've had it 2 years and am sick of it already. Never does it cold. Only when hot and it is intermittent. No lights on. Great oil pressure. It's not plugs or wires. Cam is good just put in new GM123 lifters so that's not. it sounds the exact same as the old lifters. Pushrods are straight rockers look good not rubbing valve covers or spring keepers. Does it with the accessories belt of. Tried 10/30 oil that didn't change it. all the rockers are getting oil. Prominent on passenger side #4 cylinder with a stethoscope. Thanks for any suggestions.
07-14-2018, 09:31 PM #2
Did you remove the alternator to intake bracket?
I have similar after my cam swap and it seems to be the alternator bouncing a little.95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
07-14-2018, 09:38 PM #3
Yep I tried that. Thanks for your suggestion. It has a new fuel pressure regulator water pump,balancer,clutch,pressure plate, pilot & throw out bearing too.
07-14-2018, 09:43 PM #4Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Exhaust leak? Pull #4 plug wire.
07-14-2018, 10:20 PM #5LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
Sounds like exhaust leak.
The Following User Says Thank You to Brandon++S For This Post:
07-15-2018, 09:12 AM #6
Thanks I'll give it a try.
07-17-2018, 11:39 AM #7Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
07-20-2018, 10:53 AM #8Xtreme Member
- 7,266
Supporting Membermanifold leak at head
08-21-2018, 01:07 PM #9
sounds like exhaust leak either exhaust manifold has a small crack or the exhaust manifold bolt on #4 broke
96 BBB 383/T56
08-22-2018, 08:54 PM #10
