Results 1 to 10 of 33
Thread: Oil psi dropping
Hybrid View
06-25-2018, 04:32 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
pick up tube fell off
Well I took the car for a very short drive today. I found there was a leaky valve cover gasket and wanted to make sure that I repaired it. I noticed when I would brake the oil pressure would drop drastically. I do have the appropriate amount of oil in the motor so I know I'm not low on oil.
so do i pull the motor out completely is is there some tricky way i can pull stock pan off with the factory k member in the car?
i tack welded the oil pick up tube on .... but that wasnt enough .... it fell off
Sent from my SM-N950U using TapatalkLast edited by zooguy; 06-25-2018 at 06:17 PM.
06-26-2018, 11:03 PM #2"The Rock"
So it was the oil pick up tube.
06-26-2018, 11:06 PM #3The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
I haven't fixed it yet ... that was a pic from when I was building the motor.
Sent from my SM-N950U using Tapatalk94 Formula "budget build" #thebeaterbird
06-28-2018, 08:53 PM #4LTX Regular
- Aubrey
- (2) 1994 Camaro Z28
- Janis Joplin's neck of the woods
- 204
My oil pressure drops drastically when I brake hard, and about half when moderately braking for a red light or stop sign. I know also that my oil level is full, but it still happens and my check gauges light will come on during a hard braking stop. The light goes off and oil pressure picks back up when the inertia settles. I only have the oil pressure gauge in the instrument cluster to go by. I have a Melling oil pump in my car with 12K miles so I'm sure it's just inertia in my car.
'94 Z28 Red, SLP Ultra Z hood/air box/spoiler, LT1 w/deletions & mods, 4L60e Pro Race build by CPT, Pacesetter LTs with stainless Speed Engineering LS1 True Duals, LS1 front brakes, Kenny Brown Double Diamond SFCs.
06-30-2018, 09:32 AM #5"The Rock"
I would check ur pick up tube as well @Ardent_Z28 . It shouldnt move that much if at all from inertia.
06-28-2018, 09:13 PM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
If you jack up the front of your car or drive up onto ramps to get underneath it and you bang on the oil pan you might hear something rattling inside of it I did it with my car and found out that my oil pickup tube fell off
06-28-2018, 09:30 PM #7LTX Regular
- Aubrey
- 204
I'll try that ^^^^^ Now I'm curious to find out. I've got the factory K-member and I don't see any way to pull the pan without unbolting the mounts and raising the engine. I've gotten pulling the engine from the bottom down to a science cuz I've done it several times.
06-29-2018, 11:07 AM #8
oil pressure drop on braking or turns typically means the oil pick-up came off as the OP discovered.
Bore scopes are pretty cheap now and using one through the oil drain hole or oil level sensor hole would show if it fell off if you can't determine if it fell off by hitting pan with a mallet. Draining the oil though should help hearing the hammer hit method though96 BBB 383/T56
06-30-2018, 09:33 AM #9"The Rock"
07-01-2018, 07:57 PM #10LTX Regular
- Aubrey
- 204
The Following User Says Thank You to Ardent_Z28 For This Post:
