Results 1 to 7 of 7
    Dec 2011
    Louisiana
    Default American Torque Thrust II/Mickey Thompsons
    IMG_1682.JPGIMG_1683.JPGI'm so happy with the way this wheel/tire combo came out I just had to show it off.
    I studied long and hard to decide on a wheel upgrade because I wanted a certain look.
    Then I did a bunch of measuring. (Measure four times then buy).
    Then I shopped what would fit by cost and looks(in my eyes).
    There are a ton of great looking wheels out there, some over priced for the construction.
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
    Dec 2011
    Louisiana
    Dec 2011
    Louisiana
    Dec 2011
    Louisiana
    Oh, Meissen, Thanks for working on the photo upload problem.
    Nolan
    LTX Regular
    Mar 2015
    Sam
    1993 z28
    Looks good, ive always been a fan of the torq thrust
    Sent from my SM-G930P using Tapatalk
  6. The Following User Says Thank You to seymour buttz For This Post:
  7. #6
    Aug 2013
    JB
    Atoka,TN
    You can't go wrong with TT2's! Looks great!
  8. #7
    Dec 2011
    Louisiana
    Wheel/tire details:
    Front and rear wheel size is nearly identical to the stock wheel package. 17x9.5 with 7" back spacing. Stock rim is 9" wide so the American's are just a 1/4" wider inside and outside.
    Front tires are Mickey Thompson Street Comp 275/40-17 same as stock tire size, they are 26" tall.
    Rear tires are Mickey Thompson ET Street S/S drag radials 305/45-17, they are 28" tall.
    The rear fender wells have to be clearanced in one spot at the inside forward lower area. A few good hits with a BFH does the job.
    I'm gonna take the wheels back off soon to paint the area that I hit with the hammer. I'll try to remember to get a photo and post it.
    Hope this helps other people trying to determine what will fit on their car.
