Results 1 to 5 of 5
Thread: Header bolts
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Default Header bolts
    What header bolts r u using.i would like to go with stage 8. Can't find the ones for lt1 cars
    Sent from my SM-G930R6 using Tapatalk
    BEAVER
    LTX Regular
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    I bought the stage 8 when I did my header swap, major pita trying to get those damned clips on. Said to hell with it and used the bolts and split washers.
    Sent from my VS501 using Tapatalk
    1995 FORMULA M6
    Aug 2013
    JB
    Atoka,TN
    ARP
    ARP, mix of bolts and studs.
    Tighten em, run a heat cycle, re tighten, repeat once or twice. Then you are set.
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    9k thanks shownomercy
    BEAVER
