Results 1 to 3 of 3
Thread: Vette wheels
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Default Vette wheels
    Would the 2011 later wheels fit the 96 z28. There 18x10 front 19x10 rear. Well the work
    Sent from my SM-G930R6 using Tapatalk
    BEAVER
    They are a 5 x 120.65mm (4-3/4”) bolt circle, so that's the same.
    Charts show the 19” x 10” for the base car as 79mm offset; 19” X 10” for the ZR1, ULZ Carbon Edition, and Z07 as 40mm offset. Which ones are you asking about?
    No 18” X 10” shown. There was an 18” X 9.5” 40mm offset used on the 2011 Grand Sport and Z06.
    40mm offset pushes the wheel toward the outside edge of the fender. 79mm offset pushes the wheel deeper in the wheel well, and may require spacers. If you can pin it down to the specific wheel, exact width and offset, I can tell you if it will work.
    Here's the best source of info:
    http://image.mamotorworksmedia.com/p...ence_Guide.pdf
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    I'm not sure but they was on an older z28,a 69
    BEAVER
