    Mar 2018
    Jm
    Default Car misfire under load
    The car has started to misfire under load say above 2500 rpm. Car has new plugs gaped at .35 supercharged 8# crane cam ignition box. Wideband shows plenty of fuel
    i wonder If it’s the plug wires? Or hopefully not the opt. I’ll look for arch of the wires tonight. Is there a way to test the opt or coil anything els y’all I should check let me know.
    Problem stsrted out out of nowhere was running great then dog shit
    95 a4
    1996 Z28
    Newark, DE
    Sounds like weak spark. It could be the opti but also the coil or wires. Def check for arching first as that is easy. You could try closing the gap to .022 or so and see if that helps. .035 seems pretty wide for 8 lbs of boost.
    Mar 2018
    Jm
    I just changed the plugs wires car won’t rev above 2500 rpm now ☠️. I’ll pull the plugs out tomorrow and see what they look like I know the car has been running rich, maybe I’ll get lucky and will need plugs or a new coil. Thanks for the feedback
    Mar 2018
    Jm
    Ok so I’m pretty sure it’s the opti... car would rev past 2500 today but still runs roughly. Misfire at idle. There is a screeching sound sounded like a belt slipping bad. I pulled off the belts for the accessories as well as well as the belt for the supercharger. Stilll makes the screeching sound. With that being said only thing it could be (only things turning) are the warred pump and opti.
    Fuel pressure looks good so I don’t think it’s a lack of fuel I fact the wide band is showing plenty of fuel a bit too much with the stupid fmu.
    1996 Z28
    Newark, DE
    Sounds like it could be your opti. Always good to have a spare around to swap it out when issues arise. Hopefully, you can find a good one as I do not think AC Delco makes them anymore.
    Johnny
    1994 formula A4
    Henderson, TN
    its almost always the opti
    Dec 2013
    SoCal
    Quote Originally Posted by TheFknJm View Post
    maybe the rotor is rubbing the cap of opti....or WP impeller is hitting the WP housing....although the later would not cause a misfire
    96 BBB 383/T56
    Mar 2018
    Jm
    Well I’ll find out soon for sure I got thr opti and water pump off last night wasn’t near as hard as I’ve seen ppl say. Heack the plugs where harder to change... then again I only got it all off haven’t had to put it on yet����♂️
    Mar 2018
    Jm
    Son of a bitch a clogged cat. New cat in and life is good. I wasted so much time but never a bad idea to have a spare opti and new water pump
  10. The Following User Says Thank You to TheFknJm For This Post:
  11. #10
    Johnny
    1994 formula A4
    Henderson, TN
    Thanks for reporting back your findings!
