Results 1 to 7 of 7
Thread: EWP LED?
    Mar 2018
    Isaac Garcia
    1996 impala SS
    Default EWP LED?
    Is there a kit or some type of diagram for a warning light when the ewp goes out?
    Dec 2011
    JeremY
    1972 NovA
    Elsberry, MO
    Quote Originally Posted by DarkSSide View Post
    I remember finding one on shbox.com a few years ago. Not sure if that site is still up and/or if its still there.
    '72 Nova "HadeSS"
  3. The Following User Says Thank You to JCzNova For This Post:
  4. #3
    Dec 2013
    SoCal
    Wiring in a light/buzzer to a inline flow switch in the heater hose would show if WP was "pumping" as the other types just show if it is getting +12v which does not indicate if a ground dropped or the EWP itself was not turning
    ...but for me in the 19 years I have had my EWP....I just keep and eye on the temp, and other, gauges.
    Another option would be to install a "A" pillar gauge, water temp, with a programmable alert temp that activates a light in the gauge
    Or mount the gauge in the lower bezel of your instrument cluster
    96 BBB 383/T56
  5. #4
    Shoebox is alive and well. He does have a circuit for adding an LED to a manual fan switch, but I don’t recall one for an electric WP.
    http://shbox.com/1/4th_gen_tech1.html
  6. The Following User Says Thank You to Injuneer For This Post:
  7. #5
    Shoebox is alive and well. He does have a circuit for adding an LED to a manual fan switch, but I dont recall one for an electric WP.
    OP Google it, there's a wiring diagram on the impala forums
    I talked to shoebox, he said he will have the site around for as long as possible, and when he decides to pack it in I may take it over
  8. The Following User Says Thank You to SSlowBoat For This Post:
  9. #6
    I have always wondered why folks will see a light going off, but not see the gauge cluster creeping.
  10. The Following User Says Thank You to shownomercy For This Post:
  11. #7
    Dec 2011
    JeremY
    1972 NovA
    Elsberry, MO
    I personally wired one because I was driving my project before I had a full set of gauges.
    '72 Nova "HadeSS"
