Thread: EWP LED?
03-28-2018, 01:52 PM #1
EWP LED?
Is there a kit or some type of diagram for a warning light when the ewp goes out?
03-29-2018, 09:06 PM #2Xtreme Member
- Dec 2011
- JeremY
- 1972 NovA
- Elsberry, MO
- 4,416
The Following User Says Thank You to JCzNova For This Post:
03-29-2018, 09:38 PM #3
Wiring in a light/buzzer to a inline flow switch in the heater hose would show if WP was "pumping" as the other types just show if it is getting +12v which does not indicate if a ground dropped or the EWP itself was not turning
...but for me in the 19 years I have had my EWP....I just keep and eye on the temp, and other, gauges.
Another option would be to install a "A" pillar gauge, water temp, with a programmable alert temp that activates a light in the gauge
Or mount the gauge in the lower bezel of your instrument cluster96 BBB 383/T56
03-30-2018, 08:49 AM #4LTx Guru
Shoebox is alive and well. He does have a circuit for adding an LED to a manual fan switch, but I don’t recall one for an electric WP.
http://shbox.com/1/4th_gen_tech1.htmlSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
03-30-2018, 11:04 AM #5Xtreme Member
- 7,266
03-30-2018, 11:53 AM #6
I have always wondered why folks will see a light going off, but not see the gauge cluster creeping.
03-30-2018, 05:13 PM #7Xtreme Member
- Dec 2011
- JeremY
- 1972 NovA
- Elsberry, MO
- 4,416
I personally wired one because I was driving my project before I had a full set of gauges.
'72 Nova "HadeSS"
