BDBRacing
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Default Engine Harness Options
    Had to fix two small nicks in my injector harness over the weekend (somehow engine ran on 2 cyl per side) and realized how old/frail the harness is.
    Any ideas or places to check out for getting basic universal harnesses? My setup is not like stock so do not want another factory harness to take apart.
    If I could find pigtails with each connector made up already with ~5ft of wire, that would be perfect.
    LS1 PCM, 24x setup.
    Mark
    Altoona, PA
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    I bet if you hit BP up he'd do a custom one off for you........since that's his thing and all.
    Is he still around?
    1996 Camaro Z28, 1994 Trans Am GT, 1985/1996 Corvette CLONE
    Is he still around?
    He is still around, just not sure how long he will be in the ltx harness game. Id move quick if u wanna contact him.
    In reality, my harness is mainly a LS1 harness.
    Mark
    Altoona, PA
    https://www.bp-automotive.com/
    Forgot to add them on the list above.
    1994 camaro
    Lehigh Valley PA
    bp still does them. quoted me 750 for a new engine/trans harness with emissions deleted and ewp integrated in last week
    2009 G8 GXP #871 - Stock and faster than my LT1
    1994 Z28 T56 - Le2 H/C, SBE, Hooker lt's, some rod ended suspension stuff, and a whole lotta tetanus
    The wrench for LTConvert's 94 Z28- Ellwein 383/LE Trickflows/ P600B/ CPT Pro Race/Pro Torque 3200
    Enrique
    93 Z28
    Houston/Clear Lake
    I got a harness from BP and is was top notch. Fyi
  10. #10
    Quote Originally Posted by 383z View Post
    BP never got back to me.
    Ah well
