Results 1 to 10 of 10
02-14-2018, 10:23 AM #1Lurker
- Mar 2014
- Wayne
- 1989 Mustang Coupe Ltx swapped
- Rome Ga
- 57
Project Foxbody Coupe lt1 396 swap
I'm moving everything over here where it should be! As I get better navigating the site over I'll be more engaged or try too lol... What started out as a 93 Trans Am 396 build has taken a few unexpected turns and now it's a 89 Foxbody Coupe Gen2 Lt1 396ci swap build...
Callies DragonSlayer crank
Callies Comstar Rods
JE/SRP forged dished pistons
AFR 220cc heads
Super Victor efi intake
Aje Kmember with coilover conversion
Torqhead 24x full kit
TH350 TCI 3600 N2O stall
Nitrous Express 75shot shark nozzle kit (came with the 93 TA)
Rear 8.8 with 4.30 gears and full spool, which will probably swapped for 3.73 later
Planning to add a 76mm turbo later so I haven't bought headers yet.... I'm swapping the 93 engine over to 95 stuff to use the torqhead kit... Heads should arrive in a few more days then they're off to Lloyd Elliot as money permits.... So between now and then I have to determine if I'm just going to run N20 or just continue the build towards a turbo setup.... Decisions decisions.... LolUsing Tapatalk
02-15-2018, 04:33 AM #2Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
Looks good. Quick question...Why go with torque head when your able to run a regular dizzy with that intake and go with a stand alone for fuel?
Formula Build Thread
02-15-2018, 01:15 PM #3Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
Another nice build!
The Following User Says Thank You to fullforce For This Post:
02-17-2018, 09:50 PM #4Lurker
- Mar 2014
- Wayne
- Rome Ga
- 57
When I bought the torqhead kit I had a regular lt1 ported intake and stock ported casting heads and it was going in a 93 Trans Am and I was/am planning on swapping the 93 timing cover to a 95, and at that time I wasn't really aware of other stand alone fuel/ignition systems so when the torqhead 24x kit came available I thought it would be a good idea because of being easier to get tuned because of the Ls 411 pcm
So this build has just kinda evolved to what it is today... LolLast edited by BrokenShadowRacing; 02-17-2018 at 09:53 PM.
Using Tapatalk
The Following User Says Thank You to BrokenShadowRacing For This Post:
02-21-2018, 04:37 PM #5Lurker
- Mar 2014
- Wayne
- Rome Ga
- 57
Heads finally get here... Gotta say I'm pleased AFR 220CC
Using Tapatalk
02-22-2018, 06:03 AM #6
Very awesome, can't wait to see this one completed.
1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
The Following User Says Thank You to myltwon For This Post:
06-13-2018, 08:09 PM #7Lurker
- Mar 2014
- Wayne
- Rome Ga
- 57
Finally found a good set of used sbc swap Dynotech 1 3/4 stepped to 1 7/8 for my Foxbody! $200 plus $40.00 shipping, guy said approximately 500 miles ran on these before he pulles the engine out to do a lsx turbo build on it... so I jumped all over this deal ! Lol..... Things just move slowly so I'll be back asap... Im saving up for 4Bolt splayed main caps installation now so the short block is coming back apart lol...
Sent from my SM-G955U using TapatalkUsing Tapatalk
06-26-2018, 04:49 PM #8Lurker
- Mar 2014
- Wayne
- Rome Ga
- 57
More parts came in yesterday.... UPR adjustable upper and lower control arms
06-29-2018, 11:19 AM #9
06-29-2018, 11:30 AM #10Lurker
- Mar 2014
- Wayne
- Rome Ga
- 57
Im going to stick with the torqhead 24x full kit since I already have it and a stand alone wiring harnesses.... Next up is having the 4 bolt splayed main caps installed then the heads and intake will be shipped off to Lloyd Elliot to be freshen up and intake ported to match like you mentioned and a custom grind cam for my setup then I'll start assembly on the car with the AJE-Kmember and coilover conversion as the car is currently sitting on blocks with nothing under it lol... Once its back to roller status I'll set the engine in and start that process. Sent from my SM-G955U using Tapatalk
Using Tapatalk
