Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
    Dec 2011
    Louisiana
    Default Lt1 top end overhaul
    I recently completed a top end overhaul on my Camaro and thought I would share the build up through a series of photos and comments. There were many setback aggravations but it's nearly complete. Perhaps what I learned may help others in the future.
    Nolan
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    That's awesome can't wait to see pics
    1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
  3. The Following User Says Thank You to myltwon For This Post:
  4. #3
    Dec 2011
    Louisiana
    The engine build was a comedy of errors from the get go. The previous owner knew what he wanted but was paying folks to work on it. This is a 385" stroker(.040 over), all forged bottom end,AFR 210 heads, comp xfi292 cam and other assorted goodies. When I bought it the valvetrain sounded bad, it stunk bad at idle and sometimes smoked a bit ot of the tailpipes. But at WOT it was a beast. I played around with it for awhile and figured out some of the random misfire issues and got it running better but it had more issues.
  5. #4
    Dec 2011
    Louisiana
    Default Continued
    The misfire issues were caused by his mechanic putting stock LT1 spark plugs in the AFR heads and also a couple of bad plug wires that sometimes fired and sometimes not. I had run into the spark plug issue once before on a different engine. Stock heads use a tapered seat spark plug, AFR heads use a gasketed seat spark plug. I put a set of gasketed seat plugs in along with a set of wires I custom built to go over the valve covers. Ran alot better but it still stunk and smoked some times. I was actually losing compression from the plugs leaking because the tapered seat plugs were tightened against a flat seat.
  6. #5
    Dec 2011
    Louisiana
    I finally decided that the engine seemed to run like it had an internal vacuum leak and made plans to pull the intake and investigate. While I was at it I planned to check out the valve train noise as well.
  7. #6
    Dec 2011
    Louisiana
  8. #7
    Dec 2011
    Louisiana
    Yep, It was what I thought. The rear four ports (5-7 and 6-8) were leaking internally. Ports were very oily. The 5-7 reminded me of another issue I discovered while doing the plugs and wires. By chance I happened to notice that the #5 and #7 fuel injector plugs were hooked up reversed. It actually ran like this, LOL.
  9. #8
    Dec 2011
    Louisiana
    The heads on this engine are AFR 1057's. AFR says DO NOT use GM LT4 intake gaskets, they will leak. Use AFR 6860 with a little bit of silicone sealant on the port bottoms. Guess what was installed on it? I think all the ports leaked slightly but the rear four were the worst because the engine slants back and the oil drainback really flooded the rear four ports.
  10. #9
    Dec 2011
    Louisiana
    Default Valvetrain
    The more I looked the more I found. The rocker arms were running all over the valve spring retainers. At this point I started looking closer at the valve spring setup and discovered several valve guides on both banks that appeared to be worn badly. I could push on the springs and make the valves move side to side in the guides. Well hell, its time to pull the heads to have them freshened up.IMG_0178.JPGIMG_0177.JPG
    The clay was a good way to check clearances that are hard to see.
    These are Crane Gold rockers.
  11. #10
    Dec 2011
    Louisiana
    The heads were a real pain in the ass to pull. I got some help after I had cut myself all up trying to get to all the hardware and bolts. Finally out;IMG_1127.JPG
