Results 1 to 10 of 13
Thread: Air n system??
02-02-2018, 01:05 PM #1LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Air n system??
I'm Getting air n my cooling system. I can ride a few days,then it gets air n. After I drive it down the road it well come out. Anybody know what might b going On?
Sent from my SM-G930R6 using TapatalkBEAVER
02-02-2018, 01:36 PM #2
Head gasket and radiator cap are usual culprits in my experience.
95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
The Following User Says Thank You to donfrye For This Post:
02-02-2018, 01:42 PM #3355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
www.fquick.com/SleepyZ
02-02-2018, 01:47 PM #4LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
02-02-2018, 01:48 PM #5LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
With my luck tho. It's probably a head down
02-02-2018, 04:46 PM #6LTx Guru
May also be a leak in the rubber line (or the metal tube on top of the reservoir) from the radiator over flow to the reservoir.
Gets hot, coolant expands, pressure cap releases coolant through line, into reservoir. Radiator cools down, coolant contracts, pulls a vacuum, which opens the vacuum relief in the cap, and the vacuum is supposed to pull coolant from the radiator to keep the radiator full, but it can't because of the leaks in the line, just pulls in air. Radiator now has air in it.
See a lot of this with vehicles this old.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
02-03-2018, 05:30 PM #7LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Thanks fellows
02-03-2018, 05:32 PM #8LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Injuneer u r talking about the line coming from radiator to over flow right?
02-03-2018, 08:55 PM #9LTx Guru
Yes, the line from the radiator neck to the coolant reservoir, under the battery. The part of the line under the battery is metal, and it can perforate due to corrosion. Could be the flexible line, or the metal tube. Or possibly that's not the problem at all. Just a suggestion.
02-03-2018, 09:02 PM #10
Beaver,
Were you able to find a cooling system tester?
Sent from my SM-G930V using Tapatalk355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
