Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Nov 2016
    Logan
    1995 Firebird Formula
    Pennsylvania
    Figured i'd post another update as it has been a while. I bought a MWC K-member and UMI upper and lower a-arms. Got the vehicle up and running and was gonna take it to South Mountain Raceway.
    It made it, but in the water box it had an oil leak which was the rear china wall between the block and intake.
    I bought a set of racestar wheels and had MT 275/60r15's mounted on the rears.
    I just got a MWC Fab 9" delivered today which I ordered black Friday and also a 4" aluminum driveshaft balanced with the joints and yoke installed.
    I also have front&rear viking coilovers with crusader valving on order from MWC, but has not been shipped yet. On that same order I had bought sub frame connectors from MWC
  2. #12
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Get it on the dyno yet? With that cam, if the trick flows are ported right, you should be in the mid 400's for sure, I'd venture north of 450.......depending on drivetrain setup obviously. Sounds awesomely rowdy!
  3. The Following User Says Thank You to Fastbird For This Post:
  4. #13
    Nov 2016
    Logan
    Pennsylvania
    No never had it on the dyno, but the transmission is a CPT Pro Race 4l60e. Thats about what I was expecting though
  5. #14
    Nov 2016
    Logan
    Pennsylvania
    Well swapping to a 582 big block with over 1000hp N/A. The lt1 will be going into my dad's fiero which currently has a 350 with a bent rod.Snapchat-1415665412.jpg20191203_140626.jpgSnapchat-1014679825.jpg
