Results 11 to 20 of 21
02-01-2018, 07:28 AM #11VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
02-01-2018, 09:39 AM #12LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
I'll be glad to get you more pictures. I should've explained better for ElkySS but the brackets I used were the sliding tracks that came with the seats and the factory mounting feet from the original seats. I basically positioned the factory feet with the Procar brackets and welded them together trying to retain a factory hight.
Sent from my SAMSUNG-SM-G900A using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
02-01-2018, 06:35 PM #13LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
Did it work? is is close to factory height?
95 Cyber Grey Formula
396 M6
LE 244/252 .636/.636 110
LE 215cc Trickflows
02-02-2018, 06:55 PM #14LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
02-03-2018, 03:10 PM #15LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
Maybe this will help. I have one with the door bar closed, one a little closer to the console and one to show the seat height near the hoop. Neither seat rubs the console but there are adjuster knobs on both sides of the seats so the knobs on the inside of the seats do touch the very bottom of the console. I don't know if that would be an issue with the more narrow (standard) version.
02-05-2018, 12:44 PM #16VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
I like the looks of these and the fact that I can adjust the back of the seat. Looks like would be fairly comfortable. Thanks for posting up more pictures @Cathead!
02-05-2018, 04:12 PM #17LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
02-05-2018, 06:25 PM #18LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
I'm seriously considering these seats. The only issue see is I can't weld so I wanna use the premade brackets. I just want close to factory ride height.
396 M6
LE 215cc Trickflows
02-05-2018, 08:10 PM #19LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
02-08-2018, 05:30 AM #20
One thing to be careful with reclining seats is the quality of the joining of the back section to the lower "seat" section. Some of the cheaper seats use very little in terms of fastening the two halves together. A poorly constructed "race" seat can very dangerous in an accident.
I run Corbeau LG1s btw, love them, very high quality.1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
