Results 11 to 20 of 21
Thread: Max rpm with 2 bolt main caps
02-26-2018, 11:16 AM #11Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
So what are the limits of the ARP mains on a 2 bolt setup as far as rwhp and RPM? Trying to decide if a 4 bolt splayed will be a must or not.
02-26-2018, 11:26 AM #12Xtreme Member
- 7,266
Supporting Memberif you're using arp bolts on the mains, you need a line hone anyway, splayed caps are cheap insurance. I'd spend the money if boost or nitrous are in plans for above 500 whp. if not, gamble.
fyi the stock rods are the weak part of an lt1
02-26-2018, 12:12 PM #13Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
No it will be part of a stroker short block I am hoping to get. I have been looking at one from VRE http://www.victoryracingengines.com/...TX&BLOCK=SHORT
Description:
Victory Racing Engines 396ci LT1 engine rounds out our LT1 line-up. It is the largest LT1 engine we produce. Whether you are looking for a street/strip package or looking for an all out race combo, the VRE 396 LT1 is the pinnacle of LT1 Performance.
Specs:
Compstar 3.875" Stroke 4340 Crankshaft
Compstar 6.000" H-Beam Rods
SRP -5cc Flat Top Pistons
Mahle Rings
Clevite Rod Bearings
Clevite Main Bearings
Clevite Cam Bearings
ARP Main Studs
Balance Rotating Assembly
Fully Machine Block w/ Deck Plates
Blueprint and Assemble
Options:
Fel-Pro Head Gaskets $39.99ea
Cloyes Timing Set $90.99
Comp Cams Camshaft $245.99
BBK 58mm Throttle Body $309.99
Piston Coating on Skirts and Tops $315
ATI Harmonic Balancer $379.99
ARP Head Studs $124.99
Upgrade to Callies Dragonslayer Crankshaft $500
Upgrade to Diamnd Pistons and Rings $250.00
Price:
$3700.00 *No Block Core Requirred*
02-26-2018, 12:18 PM #14Xtreme Member
- 7,266
02-26-2018, 05:12 PM #15Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
https://golenengineservice.com/engin...lock-396-550hp Just showed this as a price comparison
Plus there is https://www.tpis.com/pages/402lt1 a 402
ooooh yeah Good luck dude remember its
It's not how fast you mow. It's how you mow fast.Last edited by Stormyweather; 02-26-2018 at 07:18 PM.
02-28-2018, 02:34 PM #16Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
After looking into this a bit further I am going to be doing a 383 as it just makes more sense especially with longevity being a consideration.
02-28-2018, 04:05 PM #17
A good balance job and detonation is your enemy, keep those two in sink and you are good to go... how do I know this,
722 RWHP, stock crank, 2 bolt.
02-28-2018, 06:03 PM #18Xtreme Member
- 7,266
03-01-2018, 06:51 AM #19
Does not have to be a stroker, as you know, RPM is the killer and if you have a bad balance job, the rotating assembly is not in perfect harmony it will cause basically vibrations in the upper RPM band, along with detonation, this will make your main caps "walk" resulting in catastrophic failure, back in the day with the ole 302 Z28"s, people were spinning those to 8000 RPM! from the factory, yes eventually a rod would peek out for some sunshine, but GM's engineering was pretty spot on as far assembling a performance motor with their balancing of the bottom end.
The Following User Says Thank You to MoeHorsePower For This Post:
03-01-2018, 10:31 PM #20Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
Well a good stroker 383 being limited to 6200 RPM's should provide me with a long lasting engine based on that if it is built right. Still looking into my main options, but a good played cap main or possibly just an ARP main might be sufficient. Still weighing all the options as I don't want to have to redo it later.
