Results 11 to 20 of 25
  1. #11
    1995 Firebird
    Western MA
    The more important question is how fast you want to spin the motor, and how fast you plan on trapping.
    S60 is limited to 3.54s whereas a 9 inch can basically have whatever you want in it. I semi regret going S60 in that light.
    I don't understand why you're limited to 3:45's?
  2. The Following User Says Thank You to Mystery Bird For This Post:
  3. #12
    Quote Originally Posted by Mystery Bird View Post
    A S60 can only go down to 3.54 gear set. In my car, 373s limit me to 140 trap with current redline.
    A turbo car could go even lower and negate the need to have OD trans.
  4. The Following User Says Thank You to shownomercy For This Post:
  5. #13
    1995 Firebird
    Western MA
    Ahhh, lowest, I was thinking highest.
  6. The Following User Says Thank You to Mystery Bird For This Post:
  7. #14
    Sep 2014
    Joel
    Colorado
    Plan on spinning motor 6500- 7000 the limit to stock PCM.
  8. #15
    Sep 2014
    Joel
    Colorado
    I just received my S60 for my Camaro with 4:10 gears, 35 spline axles, 1/2" studs and so on. Very nice quality and price for what you get. You just missed the 10% off and free shipping sale.
    I have a Moser 12 bolt in my Firebird. It is nice heavy duty with 3:90 gears but they starting to whine just a bit, I drag race it and street beat it for about 6-7 years now, that is why I went with an S60 this time for the Camaro, plus the sale and free shipping.
    The limit to the 12 bolt is limited ability to take abuse. The S60 is it's inability to go beyond 3.54 gears limited trap speed to 140. 9in has a wide gamit of gear selection and strength.
  9. #16
    S60 carries a 25# weight penalty over the 12-bolt, but has lower (5%) power losses than the 12-bolt (7%). 9-inch pushes the power loss to 10%. Doesn't the S60 require a shorter driveshaft?
    My 12-bolt received very limited wear and tear. But when the car still had the T56 and a McLeod Street Twin, and I was doing 5,000+ RPM dumps on sticky tires, there always seemed to be a subtle change in the sound of the gears after a day at the track. I would say limit the 12-bolt to 750 HP behind a standard trans. With the TH400 it seems much more tolerant of abuse.
    As far as swapping center sections with the 9-inch, the torque arm mount, at least with Moser's design, complicates things, particularly if you are try to do the swap in a rush at the track.
  10. The Following User Says Thank You to Injuneer For This Post:
  11. #17
    Sep 2014
    Joel
    Colorado
    Thank you for your insight and opinion as always you bring light to the situation.
  12. #18
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Can't you just use a shorter tire with the S60 to help with the ratio issue?
  13. #19
    Taller tire.... with a 140 MPH trap speed/red line limit, going from a 26" --> 28" tire would add about 10 MPH. Or 28" --> 30", but that requires fender mods.
  14. The Following 2 Users Say Thank You to Injuneer For This Post:
  15. #20
    Apr 2012
    Cameron
    Dover, De
    Quick Performance 9", Moser 31 Spline axles, Strange S Case, 4.11's w/ factory tracklok.
    Formula Build Thread
  16. The Following User Says Thank You to Sahara54 For This Post:
