Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Sep 2014
    Joel
    Colorado
    Default Looking for some recommendations on a rear end. On the fence on a 9in or S60. Spool
    Running 385 Ltx block with sold roller with 650 in of lift, ported polished AFR 227 with lt-4 intake ported to match, mono blade TB, D1SC with 3.4 pulley, 12 rib. Intercooled, bult 4L60E w brake. Looking to run 28 10.5 drag radial tire. Just want to get the built rear to handle abuse.
    I had a 385 with 227 eliminator afrs and a p1sc doing about 10 lbs of boost thru a built 6spd.
    Loved my 9"... 35sline axels with locker.
    Locker is a bit annoying with a stick, but "racecar stuff..."
  3. The Following User Says Thank You to popo8 For This Post:
  4. #3
    LTX Regular
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Stock 10 bolt can't handle that??....lol
  5. #4
    Sep 2014
    Joel
    Colorado
    Quote Originally Posted by Brandon++S View Post
    Ya I wish. It won't handle the mild built 383 on stick tire
  6. #5
    Dec 2011
    Mark
    Altoona, PA
    Strange S60 here. 4:10s, 35 spline axles and the true trac spiral gear locker, Strange Ultimate cover, and running ET Pro Drag Radials. Takes one hell of a beating. Like Popo8 mentioned, locker in a stick can be annoying at times. Why? Because race car. LOL. Heres how I would rate the rears offered for our cars. This is just my opinion. Dont forget a good yoke, u-joint and a good drive shaft.
    1. Nine inch.
    2. Strange S60
    3. 12 Bolt / 8.8
  7. The Following User Says Thank You to 1QUICKZ28 For This Post:
  8. #6
    The more important question is how fast you want to spin the motor, and how fast you plan on trapping.
    S60 is limited to 3.54s whereas a 9 inch can basically have whatever you want in it. I semi regret going S60 in that light.
  9. The Following User Says Thank You to shownomercy For This Post:
  10. #7
    I have a Trick Chassis 9"....still have to get it in the car, but its stout!
    1996 T/A - 383, BW S-475, TH350, Trickflows, LE Cam, Revmax
  11. The Following User Says Thank You to gunters96lt1 For This Post:
  12. #8
    Dec 2010
    west chciago
    i have a strange s60 i love it but some days i wish i had a 9" so i can have to centers that i can swap out for what ever im doing that day
  13. The Following User Says Thank You to shadowbandit For This Post:
  14. #9
    Aug 2013
    JB
    Atoka,TN
    I have a S60 and no regrets. I wasn't ready to go 9 inch four letter f-word.
  15. The Following User Says Thank You to Cathead For This Post:
  16. #10
    1995 Firebird
    Western MA
    I just received my S60 for my Camaro with 4:10 gears, 35 spline axles, 1/2" studs and so on. Very nice quality and price for what you get. You just missed the 10% off and free shipping sale.
    I have a Moser 12 bolt in my Firebird. It is nice heavy duty with 3:90 gears but they starting to whine just a bit, I drag race it and street beat it for about 6-7 years now, that is why I went with an S60 this time for the Camaro, plus the sale and free shipping.
  17. The Following User Says Thank You to Mystery Bird For This Post:
