Results 1 to 4 of 4
Thread: Crank Trigger
    Oct 2013
    Evansville, IN
    Default Crank Trigger
    Is it possible to use a crank trigger with the OPTI behind the balancer??.... I need to take a closer look to see if I can mount the wheel to my ATI balancer, but I'm more concerned with being able to mount the sensor.
    does anyone have any pics to share??
    thank you!!
    Tim
    96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
    1996 Z28
    Newark, DE
    I am not sure of your crank pulley setup but I am using a crank trigger mounted to the front of the balancer which would not affect the opti position at all.
    Oct 2013
    Evansville, IN
    Thank for the pic!!.... I'm running an ATI serpentine belt balancer so the front of my balancer is clean... looks like I can do what you did.
    1996 Z28
    Newark, DE
    You might need to run small spacers for the sensor mount to clear the opti plug wires but it will work.
