Results 1 to 6 of 6
Thread: Wanting more traction
11-09-2017, 07:17 PM #1Lurker
- Oct 2017
- SAM
- 2008 G8 GT 1999 Z28 6M Pewter Sold 15 Q50S
- High Point Nc
- 15
Will a 275/45/16 fit without hitting the frame or upper arms on the rear. I plan on using OE 16x8 rims, I have mounted 275's on 8 rims. Thanks guys.
11-09-2017, 07:44 PM #2LTx Guru
275 was the factory width on the SS, WS6 and Firehawk. Ditto on the 25.6 diameter. Yes, those cars ran 17 wheels, but its only the tire section width, diameter and offset the determines what works. Shouldnt be any problems on the stock 16 wheels with their 55mm offset. Many run 315s in the back, a bit tight, but possible. No upper arms" in the back.
11-10-2017, 02:19 PM #3Lurker
- Oct 2017
- SAM
- High Point Nc
- 15
Finding a 275/45/16 is tough. Only 1 or 2 tires available and they are drag radial. I was hoping for a street tire first can't find any 285/40/16's either.
11-10-2017, 03:41 PM #4LTx Guru
I thought you wanted to know if they would fit... not where to find them. I've only seen comp tires in that size.
11-15-2017, 02:11 PM #5Lurker
- Oct 2017
- SAM
- High Point Nc
- 15
Installed some boxed BMR lca's. And purchased a set of 17x9 SLP-SS 10 spokes so that I can go with a 275/40/17 (stock size) for added traction. Next on the list will be LCA relocation hangers. Thank you Injuneer. I've been learning alot about my f body lately.
01-26-2019, 10:23 PM #6
I just squeezed some c5 zo6 10x10.5 285/40/18 on the back I had to work the rear finder wells just a little t get it to fit and take out haft the bump stops. .....nothing to really do with your question I just did it so wanted to tell somebody, my wife wasn’t impressed ♂️
