Results 11 to 16 of 16
Thread: Rearend movement
10-24-2017, 02:23 PM #11Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
I thought he was taking about movement.
10-24-2017, 06:07 PM #12
I will check the brakes when I get home Friday. But the panhead bar is still there and the bushings look good. I had the back of the car jacked up and couldnt move there rearend at all thats why idk why its moving when driving.
10-28-2017, 04:55 PM #13
Rearend movement
I fixed the brake problem. But the rearend movement idk nothin out of the ordinary.
10-28-2017, 05:59 PM #14VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
10-29-2017, 10:49 AM #15
What you said hitting the caliper bracket. I guess thats what Im going to try next. Im getting irritated I cant figure it out.
11-05-2017, 11:55 AM #16
Rearend movement
5/32s play to much in the drivers side axle? Passenger has 3/32s. I just cant figure out this movement issue. I took the lcas off and the pan head brace and the bushings look hood
Sent from my iPhone using TapatalkLast edited by Slow 30th; 11-05-2017 at 12:39 PM.
