    Mar 2010
    Sean Foster
    1995 Trans Am
    Barboursville WV
    Default Remote Door lock key fob issues
    I've tried new batteries and even replaced the key fob itself. Seems like the signal is real weak. I can hover it around the back glass and keep pushing the button and it will eventually unlock. Didn't know where to start or if I could extend the antana in the vehicle any way.
    Sean Foster
    383 AI 200cc/custom grind w/full bolton's. 4L80E w/edge 3600 stall, Moser 12 bolt w/4.10 A/C & Hitch= true street
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    Just a suggestion but mine did the same thing when my car battery started to go dead.
    Sent from my A621BL using Tapatalk
    1995 FORMULA M6
    Apr 2009
    93 Bird
    West Wisconsin
    Mine was getting worse and worse when I was still driving it. Maybe someone else has figured it out. I definetlty havent.
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    I have the same issue. Something about BCM that makes it a mud duck.
    ... on my tablet using Taptalk
    Cameron
    Dover, De
    Mine is the same as everyone else...fresh battery in both.
    Formula Build Thread
    manual locks ftw
    No BCM in a 95. There is a "receiver" in the passenger side kick panel. BCM is in 96/97 only. Try holding the transmitter close to the receiver to see if it gets better.
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Ok the thing is still a mud duck. Have to be right on it. I sometimes tap my key fob on the t top then push button it works then.
    I think some people may have opened up the fob units and found corrosion on the printed circuit board, interfering with the button motion. Filed away in the back of my memory, from other sites I follow.
  10. The Following User Says Thank You to Injuneer For This Post:
  11. #10
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yeah I cleaned mine but sometimes. I have to give it a nudge.
