Results 11 to 18 of 18
Thread: LS style steering shaft
05-31-2018, 04:01 PM #1110 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
There's no U-joint at the bottom of LT1 steering shaft, its a rag joint which is just a rubber disc. It works but degrades over time causing sloppy steering. The LS shaft used U-joints which tighten the steering plus aren't as big which increases header clearance (some have had issues with the rag joint contacting their header tube). The two shafts side by are in the first pic:
http://www.ltxtech.com/forums/showth...aft-*Write-Up*-Josh
co-owner of BDBRacing.com
NMCA OC 9004
05-31-2018, 08:06 PM #12Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
My 95 has a u joint. Isnt the ls one smaller?
05-31-2018, 09:56 PM #13"The Rock"
06-01-2018, 11:50 AM #14LTx Guru
06-01-2018, 12:30 PM #15Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Yeah I'll have look again. The one I saw was at the rack, dont remember seeing the other.
06-01-2018, 02:26 PM #16LTx Guru
Stock LT1 components diagram:
11-06-2018, 03:02 PM #17
Josh, did you end up making these LS/LT shafts?
S60 rear
11-08-2018, 09:31 PM #1810 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Yes, I have 3 of them re-splined just haven't gotten around to putting a tack on them and painting.
@FlyinzLast edited by 96LT1355Z28; 11-12-2018 at 02:16 PM.
-Josh
NMCA OC 9004
