Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
  1. #11
    I have a generic solenoid up front for line lock and a summit prop valve which IIRC was a reboxed wilwood.
  2. #12
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Smj kit on the way
    Sent from my SM-N910T using Tapatalk
  3. #13
    Apr 2009
    93 Bird
    West Wisconsin
    I'm pretty sure mine is the sjm branded line lock
  4. #14
    Quote Originally Posted by zooguy View Post
    Smj kit on the way
    Shoulda talked to @Fastbird
  5. #15
    Apr 2010
    Troy
    It showed up today installation tomorrow
  6. #16
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Thanks for the plug @popo8 but I don't do the ABS delete's.
  7. The Following 3 Users Say Thank You to Fastbird For This Post:
  8. #17
    Sep 2012
    Chris P. Bacon
    Lansing MI
    I've got this Wilwood from summit, I didn't know what one i needed so i got the one that seemed like it did the most stuff lol. Goals were to get rid of the giant ABS block and be able to add line lock eventually. WIll this do that?
    https://www.summitracing.com/parts/w...stionsanswers/
    Can any of you pros point me to a good install instruction for our cars as to what lines go to what ports? I'd love to dial back the pressure in the front just a hair now that i've got the V brakes.
    '94 Formula 6spd
  9. #18
    There is a data/install sheet on the Wilwood site that identifies the ports.
    http://www.wilwood.com/PDF/DataSheets/ds715.pdf
    One line from MC to valve for front brakes. One outlet port on valve for each front brake. In effect, the valve body functions only as a "tee" for the front. Does not change front pressure.
    One line from MC to valve for rear brakes, one line from valve to rear brakes. Adjustment reduces rear brake pressure to avoid lockup.
    No need for the brake switch.
    All valve connection are 3/8"-24, for 3/16” line. All your car brake lines are metric.
    Line lock can be located in the front brake line from the MC to the valve.
  10. The Following User Says Thank You to Injuneer For This Post:
  11. #19
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Thanks!!! That sheet makes is sound pretty simple. Any idea if the stock lines can be bent to make them work if you mount the valve where the ABS block is?
    Obviously I'd have to grab an bender and tweak them but i'm wondering if they're long enough or if i'm going to need to make some new ones. And for the line/port sizes i'll just have to grab a couple adaptors?
    Sounds like it won't do what I originally wanted and bring the fronts down a little, i'll either have to change to a less aggressive pad or just keep using my foot to adjust pressure. They don't lock the fronts much now that it's got good tires, but I always worry in a panic i might hit too hard initially and lock them for a second. But at least it will drop a couple pounds off the front end and clean things up a lot.
    '94 Formula 6spd
  12. #20
    Sep 2012
    Chris P. Bacon
    Lansing MI
    I did some googling and don't see an adaptor, also saw that some cars have different sizes for front and rear fittings. And it sounds like new lines might be easier than trying to rig up the stock lines to make them work.
    '94 Formula 6spd
