Results 1 to 10 of 21
Thread: wolfe 6 point bolt in install
05-30-2017, 07:06 PM #1Xtreme Member
- 7,249
Supporting Memberwolfe 6 point bolt in install
didn't know where to put this, figured since in a way it's chassis stiffening related it may as well go here. anyone have an install guide or tips for installing a wolfe 6 point bolt in bar? I searched and couldn't find much. just a general guideline of lining it up etc. a measurement off something would be nice.
thanks in advance
05-30-2017, 07:34 PM #2Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,438
http://www.wolferacecraft.com/instru.../fbboltrb.aspx
Sent from my LG-H900 using Tapatalk
05-30-2017, 08:00 PM #3Xtreme Member
- 7,249
05-30-2017, 08:08 PM #4LTx Guru
- 2,279
The NHRA Rule Book has diagrams showing spacing of the main hoop relative to the driver's helmet, details of required upper and lower plates for bolting the main hoop to the floor of a unibody vehicle, etc. Might help a bit. I can post a .pdf if you want.
05-30-2017, 08:30 PM #5Xtreme Member
- 7,249
05-30-2017, 10:51 PM #6LTx Guru
- 2,279
The pictures on the Wolfe website of the 6-pt bolt-in on the website gives some idea of the main hoop location and the rear bars.
I'll post the NHRA info in the morning.Last edited by Injuneer; 05-31-2017 at 10:04 AM.
05-31-2017, 09:49 AM #7Lurker
- Jun 2015
- Ryan
- 1994 Camaro Z28
- Minnesota
- 372
if I can remember it take some photos and measurements of mine when I get out of work, I run the same cage
The Following User Says Thank You to agenthol302 For This Post:
05-31-2017, 09:51 AM #8Xtreme Member
- 7,249
05-31-2017, 09:53 AM #9LTx Guru
- 2,279
2017 NHRA spec
The Following 2 Users Say Thank You to Injuneer For This Post:
05-31-2017, 11:23 AM #10
I might be wrong, but I don't think a wolfe bolt in cage welded in place would be legal. If you read the rule book it says:
Unibody cars with stock floor and firewall (wheeltubs permitted) may attach roll bar with 6-inch x 6-inch x .125-inch steel plates on top and bottom of floor bolted together with at least four 3/8-inch bolts and nuts, or weld main hoop to rocker sill area with .125-inch reinforcing plates, with plates welded completely.
The reason I'm thinking it's not legal is because the Wolfe bolt in bar bolts to the floor down in the well behind the driver's seat, not up on the rocker sill area. I may be totally wrong on this, but I'd check it out before you weld it in place.
Also, I see you are in the Lehigh Valley area, do you have the roll bar already? If not, I have one I just took out of my car that I'm looking to sell. Only problem is it wont work with factory door covers.
