Results 21 to 30 of 40
Thread: Help me blow my budget on my C4!
04-22-2017, 02:43 PM #21
I emailed them a few days ago because I lost my cam card and I had a response with the card in a few hours.
I do believe it will take awhile for the work to be completed, though.
Sent from my VS987 using Tapatalk
04-22-2017, 04:53 PM #22
Thanks for all the info guys, I am going to do a general rebuild + LE package, and the other supporting goodies. Might hold off on the gears.
Just a quick clarification question, when searching for the main, rod bearings, rod bolts etc are they all the same for any gen II sbc? Or is there a reliable kit that contains it all? Summit has something but I don't know if thats recommended.
I already have head gaskets but researching last night the 9966PT I bought from fel pro, are apparently wrong? Their site listed those for a 94 C4 but just googling around, their compressed thickness is wrong and compression will be off.
04-22-2017, 04:58 PM #23Xtreme Member
- 7,266
04-22-2017, 05:22 PM #24Xtreme Member
- 7,266
Supporting MemberI used these https://m.summitracing.com/parts/mrg-5716g
along with these parts , the flywheel dowel you shouldn't need, but everything is here, even the gm white spring and 1 piece steel oil pump drive shaft
you MAY need different sized bearings, as you need to measure your rod and main journals with a good micrometer and dial bore gauge. with these parts I set everything to .0022-.0025 clearance.
04-22-2017, 06:05 PM #25
04-22-2017, 06:33 PM #26Xtreme Member
- 7,266
04-22-2017, 06:40 PM #27
04-22-2017, 06:41 PM #28Xtreme Member
- 7,266
04-22-2017, 06:57 PM #29LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
Definitely 1.6 rockers. Most of the cam cards I've seen, the lift numbers are factored based on 1.6 ratio.
Sent from my SAMSUNG-SM-G900A using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
The Following User Says Thank You to Cathead For This Post:
04-22-2017, 07:07 PM #30"The Rock"
I have some forged pistons and rods for sale if u decide to go 383.
