Results 1 to 3 of 3
    Apr 2009
    Rob Warrick
    95 Camaro z28
    Lexington NC
    Default Need help 24x possible crank trigger issue?
    Been working on the tune for awhile have it pretty close to done but a new issue has come up. I had a problem with it running off the in park timing table I figured that out and fixed it last year. First ride this year I was getting help with it and first WOT pull it broke up in the upper rpm and looking at the log it shows the RPMs jumping all over when it broke up. Never had that issue in any previous logs and not sure what it could be. Logged no knock timing was at 32* AFR 13.0 ideas?
    95 6 speed
    385 nitrous build 9.80 goal
    build- http://ltxtech.com/forums/showthread.php?t=5286
    jacksonville, florida
    Did you ever get it fixed?
    forged 383,9.6:1,280xfi, trickflow heads,edlebrock lt4 intake,moser 12 bolt w/373
    Apr 2009
    Rob Warrick
    95 Camaro z28
    Lexington NC
    best we could figure is it had interference from the alternator. Moved the sensor wire away from it and haven't had an issue since.
