Results 1 to 6 of 6
    Dec 2011
    Mark
    Altoona, PA
    Default Well I removed the traction control and ABS on the kids car.
    Well my oldest son bought a 95 Camaro a year ago. We rebuilt the T56 last year and finally got it in the garage to get it all finished up and going for him this year. After replacing the water pump and Opti he was asking what all this stuff was because my 93 doesn't have it. I said it all useless BS. It's for people that can't drive. LOL. He proceeded to ask if we could remove it. So after some research it was time to pull the traction control and then we decided to pull the ABS while we were at it. So it's all gone. I'll post up pictures of the finished product a little later. 4:10 gears are next and future plans are a nice 383. We already have a set of heads and cam. He wants to do everything at once but keeps forgetting he's on a tuna budget. He has the car addiction. LOL.
  2. The Following 2 Users Say Thank You to 1QUICKZ28 For This Post:
  3. #2
    LTX Regular
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    Nice! I plan on removing my ABS later this year. Did you buy a kit or piece it together yourself?
    Sent from my A621BL using Tapatalk
    1995 FORMULA M6
  4. #3
    Dec 2011
    Mark
    Altoona, PA
    Pieced it together myself.
  5. The Following User Says Thank You to 1QUICKZ28 For This Post:
  6. #4
    Aug 2013
    JB
    Atoka,TN
    Looks great, so much cleaner without that big abs block to work around.
  7. The Following User Says Thank You to Cathead For This Post:
  8. #5
    Sep 2014
    Joel
    Colorado
    The ABS delete looks good. Wear did you locate the cables to delete the traction control?
  9. #6
    Dec 2011
    Mark
    Altoona, PA
    Quote Originally Posted by Camaro96 View Post
    Bought a Throttle cable and cruise control cable for a non traction control vehicle. Then removed everything else. Will need to have computer tuned to have everything turned off.
  10. The Following User Says Thank You to 1QUICKZ28 For This Post:
