Results 1 to 5 of 5
    May 2016
    Steve F
    1993 Camaro Z-28
    Akron, OH
    Default Will not crank over
    I'm now at my wits end with our 1993 Camaro. We had a bad starter so we changed it for a new one. While adjusting it with a shims and having to clearance the convertor shield that car was turning over and then all of a sudden it stopped cranking over.
    Figured we ran the battery down....charged it up no change. Heard the click from the tdr in the dash and the starter would buzz. Changed the starter again..still nothing. Checked the key, and the resitance on the lock cylinder...passed. Put in a new theft deterrent relay, checked the voltage at the relay, etc...still clicks, starter buzzes, nothing else.
    Now the fans turn on when you turn the key to start, still getting a click from the relay and a buzz from the starter. Heck out of desperation we changed the battery and the computer....
    This is killing me!
    The FABRICATOR!
    Jul 2011
    southern illinois
    Check your grounds and power leads. You may have had a loose or corroded connection that got hot when you were doing all the cranking when adjusting shims
  3. The Following User Says Thank You to firebird_1995 For This Post:
  4. #3
    LTX Regular
    Aug 2013
    Gary
    1998 Trans Am
    Florida
    When the starter buzzes/clatters, it means it is starved for current. Like Chris suggested, check the heavy wires from the battery to the engine, ground or hot wire. Sometimes, the damage or corrosion is hidden under the insulation.
  5. The Following 2 Users Say Thank You to GaryDoug For This Post:
  6. #4
    May 2016
    Steve F
    1993 Camaro Z-28
    Akron, OH
    Turns out it was the ground wire from the battery. We had bolted it the engine mount, just accidently bolted it to the rubber one - moved it over to the block and she cranked right over.
  7. The Following 2 Users Say Thank You to Speedrcr For This Post:
  8. #5
    Good stuff!!! Glad ur problem is solved. Sorry it wasnt b4 throwing all those parts and work at it.
    OWNER/ADMIN
  9. The Following User Says Thank You to popo8 For This Post:
