Page 7 of 7 FirstFirst ... 34567
Results 61 to 65 of 65
  1. #61
    The FABRICATOR!
    Jul 2011
    southern illinois
    Looking forward to seeing you again Jeff. Good luck at the event
    Sent from my Pixel 2 XL using Tapatalk
  2. #62
    May 2014
    Karl Ellwein
    1995 Impala SS
    Maryland, USA
    http://www.ellweinengines.com/Donovan/BilletERE016.jpg
    (one of your early engine blocks)
    Down here in Maryland, at Ellwein Engines, we are hoping to see the car in 2020 and we are rooting for you Jeff.
  3. #63
    Quote Originally Posted by Karl Ellwein View Post
    Whooooa!
    LTXtech.com is my drug...
  4. #64
    Mar 2015
    Jeff Green
    1996 Impala SS
    Fishers, Indiana
    That's cool to see it again!! Is it going in another Impala?
  5. #65
    Mar 2015
    Jeff Green
    1996 Impala SS
    Fishers, Indiana
    Tear down for the winter thinking it should be normal maintenance. All was good until I pulled the first piston out. It is collapsing the skirts on the pistons and pushing the top of the piston into the cylinder walls.
    Easy fix but an expensive one!! Diamond is making a custom piston with a thicker .200 skirt to solve the issue. They cost twice as much as my current pistons so it better solve the problem.
    Everything else looks good!! I'm sure that will be the case until the first pass of the year and you turn the power up
